How can I display edit screen when task is transitioned
Akira Sekine March 24, 2015
I'm managing some projects & we are using Kanban board for each projct. I see difference between each kanban and Edit screen is not displayed when the task is transitioned in a certain project.
We use the same workflow in all projects so it may not be related to workflow.
Is there any configuration I should take a look regarding this?
What I want to do is that to display edit screen everytime when the task is manually transitioned like below.
Udo Brand
March 24, 2015
You need to add the edit screen as transition view within the transitions of your used workflow.
So the steps are
  1. Create a draft of your workflow
  2. Click on a transition (where you need to add the edit screen)
  3. Click edit and select your edit screen as transition view
  4. repeat this for other transitions
  5. publish your draft workflow (save a backup of your old workflow)
Akira Sekine March 26, 2015
Hi Udo
Thanks for your information. I can show edit screen by adding it on transition.
Thanks again.
Akira
Register today
