How can I export more than 1000 rows of filter results?
Steve Hooczko
When I run a filter and do the export CSV or Excel it only exports 1000 rows.
How can I export as many rows as I like?
2 accepted
Manoj Gangwar
Hi @Steve Hooczko ,
You can break the JQL to multiple parts using the created date range.
For ex- project = ABC and created >= 2024-01-01 AND created <= 2024-07-01
Check the results if it is more than 1000 then reduce the date range. After that again run another JQL for next part of issues.
Ex- project = ABC and created >= 2024-08-02 AND created <= 2024-12-01
As so on......
Steve Hooczko
It took some more work to get all the data, but your solution worked.
Thanks for responding.
Like Yohei Umetsu_NRI_ likes this
OMAR MOHAMED AHMED MOHAMED FATHY
try add on free of charge called status time free, and select the JQL , and Fields you want then export
3 votes
Aron Gombas _Midori_
If you don't want your end-user waste their valuable time with manipulating request parameters or splitting the large result set to smaller chunks, just use the Better Excel Exporter app to export more than 1000 issues to standard Excel files (XLSX).
It just works.
(Discl. it is a paid and supported app developed by our team. Free for 10 users!)
Mohamed Riza August 31, 2024
Hi @Steve Hooczko
There are some workarounds to get more than 1000 users. These are explained in the following KB: https://confluence.atlassian.com/jirakb/export-over-1000-results-to-excel-from-jira-cloud-779160833.html
Hope that helps.
Trudy Claspill
Nice! I did not remember the URL parameter.
Like Mohamed Riza likes this
Trudy Claspill
Hello @Steve Hooczko
If you are using the UI there is a hard limit of 1000 issues for the export. You would need to refine you filter to get the issues in groups of 1000 or less, modifying you filter to get another group and export each group separately.
There may be third party apps that would enable you to export more than 1000 issues at a time. Are you willing to consider an app?
Or you can use the REST API to make multiple calls to retrieve the issues and save the results.
Hannes Obweger - JXL for Jira
Hi @Steve Hooczko,
just to add to @Manoj Gangwar's answer: If the issues that you're interested in have a (more or less) continuous sequence of issue keys within a project, another trick is to break your search up into smaller chunks using a condition like e.g.
issuekey >= "PROJ-1" AND issuekey < "PROJ-1000"
... and so on. This way, you at least don't have to fiddle around with your query to only hit <1000 issues.
Of course, as already suggested, it would certainly be easier to utilize one of various Marketplace apps that allow circumventing Jira's 1000 issue export limit.
If I may provide a specific recommendation, this would be easy to do using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
Plus, its export feature does all the work for you to work around Jira's 1000 issue limit:
Best,
Hannes
