How can I filter issues by project lead?
Камиля October 15, 2024
JQL -search cannot find the issues by project leads.
2 accepted
3 votes
Nikola Perisic
October 15, 2024
Welcome @Камиля
Try using this query:
project in projectsLeadByUser(username) AND status = Open
for username add the profile ID which is shown in your screenshot after lead keyword. This is example query that lists all of the issues that are in Open status, you can adjust it to your needs.
Reference: https://support.atlassian.com/jira-software-cloud/docs/jql-functions/
Jim Knepley - ReleaseTEAM
Hi @Камиля
You might try using the "projectsLeadbyUser()" function to find issues in projects that a specific user leads.
project in projectsLeadByUser("Камиля")
ref: https://confluence.atlassian.com/jirasoftwareserver/advanced-searching-functions-reference-939938746.html
