How can I find issues that have linked issues of type X in a status Done ?
Andrey Ponomarenko March 17, 2022
Hello! I am using JIRA Cloud.
Let's say I have two issuetypes: X and Y.
And let's say there are different possible relationships between issuetypes X and Y.
For example: related to, is blocked by, and so on.
I wanna
1. Find all issues of type X that have related to issues of type Y, where every related issue is in status Done
2. Find all issues of type X that have related to issues of type Y, where at least one related issue is in status Done?
How can I achieve that? Looking for exact solution if possible.
Thanks in advance!
Craig Nodwell
issueLinkType Documentation
issueType
This link has links to fields functions keywords and operators and should give you a lot of help.
Advanced Search Reference Jira Cloud
This would be my approach, I hope this helps:  (it may need some tweaking to get what you are looking for but this should get you started).
1. issueType in (X,Y) and issueLinkType = "related to" and status = Done
2. issueType in (X,Y) and issueLinkType = "related to" and statusCategory in ("To Do", "In Progress", Done)
Andrey Ponomarenko March 21, 2022
Hello! Thank you for your answer!
1. This JQL returns not just issues of type X, but also Done issues of type Y
I wanna get issues only of type X.
Also this JQL returns issues of type X in status DONE. But I do not care in what status is issue of type X. I wanna get all issues of type X regardless of type X status. The only criteria for issue of type X is that all related issues of type Y are done
2. This JQL again return issues of both types X and Y. But I need only type X
Any Ideas how to improve your JQL?
Craig Nodwell
Sorry I cannot.  :( Maybe someone else has ideas beyond mine.
However with a plugin for better filter results you could make this happen, again this is only on me there may be others in the community that may have knowledge beyond mine.
Re:
Scriptrunner would give you expanded jql functions like linkedIssuesOf()
If you are setting your resolution on Done tickets this would find all tickets in x that are linked to tickets that are linked that are closed
issue = X and issueIssueLinkType = "depends on" AND issueFunction in linkedIssuesOf("resolution is not EMPTY")
JQL Search Extensions would give you this
issue = X and issueIssueLinkType = "depends on" and linkedIssueStatusCategory not in ("To Do", "In Progress")
Like Alex Sedunov likes this
