How can I generate weekly utilization reports for each of resource using custom chart?
karthick_s February 14, 2022
Hello Team,
  1. I want to forecast the resource planning vs availability for the next 2 or 3 weeks
  2. Instead of the "Time Report" widget, I want the same kind of weekly/monthly utilization report in the Custom Charts widget.
How can I achieve this?
Teodora V _Fun Inc_
Hi @karthick_s
It would really depend on how you track that info in Jira.
One option you can do is create your report using Original Estimate vs Remaining vs Time Spent and observe if it fits your entire use case.
If you are using an app for your resource planning (e.g. Tempo Planner), Custom Charts can't pull that info yet (but we can add it to our Integration backlog)
karthick_s February 15, 2022
Hi @Teodora V _Fun Inc_ ,
Thanks for your reply
As of now, I'm getting utilization reports like this using the "Time report" widget. Iin JIRA itself it would pivot the data based on assignee with their amount of time spent for the respective day
But I want this kind of information in "Custom Chart for JIRA using Custom Chart Widget".
So, want to know it is possible how can I do this? Because I'm new to this Custom Chart for JIRA
Thanks in advance
