I'm trying it this way: in the flow properties, I add the jira.permission.edit.group property and the group ID in the value. But it does not work. What can I do?
Hi @Ivan Monma
Have you tried entering group name instead of group ID ? You can refer this article - Permissions based on Workflow Status for more details. If this doesn't help, please share a screenshot here.
Yes, I tried the group name and ID, as per this guidance 'https://developer.atlassian.com/cloud/jira/platform/changelog/#CHANGE-1010'. Both didn't work.
Thank you for confirming and providing the screenshot @Ivan Monma
Can you please also verify whether the permission scheme is not allowing user roles that permit a larger group of people to edit issues. If only user groups are specified in the permission scheme, the jira.permission.edit.group property appears to work effectively by restricting access. However, it seems that the roles in the permission scheme are bypassing the property check.
I combined workflow properties with role permissions and it worked. Thank you very much!
Learn more
