How can I mention Slack users from a Jira automation?
shimizu.jun August 13, 2020
Slack can mention  using @.
Included a "mention" in the message using automation's Slack notification.
As a result, there are some who can mention and some who cannot. If can not, it will be displayed as plain text.
Does anyone have the same problem? Is there a solution?
Sample(Message)
Hi,Mr Smith. you need check this.
<https://*******.atlassian.net/servicedesk/customer/portal/14/{{issue.key}}|{{issue.summary}}(creator:{{creator.displayName}})>
@John Smith
*@john_smith-->The same string as when using the mention function in slack(copy from "slack" and paste to "automation")
4 votes
JD
August 18, 2020 edited
Hi @shimizu.jun
You can mention a user with their Slack member Id (not the display name). The syntax would look something like:
 <@ABC123>
To find the user id you can go to the users profile in Slack, tap the more button and copy member id. (Slack removed username mentions due to GDPR https://api.slack.com/changelog/2017-09-the-one-about-usernames)
Currently we can't do mentions on the fly. We have a public ticket for better mentions here: https://codebarrel.atlassian.net/browse/AUT-1772
John
shimizu.jun August 25, 2020
My problem is solved. Thank you very much.
Daniel Eads
November 12, 2020
As a follow-up on this, we've provided a script that can sync the Slack IDs with Jira, in order to dynamically mention users through Automation rules again. Instructions and a link to the script are on this Community article. Cheers!
noa
Do you plan to give a fix that will do it automatically - this script I will have to run it manually on each new person joining Jira
Daniel Eads
December 21, 2020
@noa the script can be scheduled using a cronjob or as a Windows Scheduled Task (depending on what system you're running it on). I would recommend doing that paired with your typical account-creation jobs. For example, if you create accounts for new employees on Mondays, have the job run every Tuesday morning.
noa
Im looking for an option from automation to tag according to the assignee some one in the slack how can I do so?
Like Coral Demyanov likes this
Coral Demyanov January 9, 2023
Looking for the same solution as @noa , Is there an automatic solution without running script?
Like 2 people like this
Jeffrey Bistrong
April 19, 2022
how would I tag a slack group? I can't figure out the ID of the group...
Jake B
May 26, 2022 edited
You can locate the group id via the API or in the url when viewing the group from a browser.  Unfortunately, @ mentioning the group using the same <@ABC123> format is not working.  Anyone aware of a different method for @ mentioning groups?
Jake B
May 26, 2022
Found the proper format for @ mentioning groups...Should have checked the docs first.
<!subteam^ABC123>
https://api.slack.com/reference/surfaces/formatting#mentioning-groups
Like 3 people like this
Jeffrey Bistrong
May 31, 2022
thanks for following up, confirmed that worked.
Let's build A Rovo Agent 🤖
Save your spot
