How can I remove auto created text field in a custom field?
emills
September 3, 2025
When I create a custom field for example a read only text field and input the field into my issue type or service request a blank text box appears in between the display name and the display description. I will post pictures to detail exactly what im experiencing.
Ultimately I want to have a display name and then a URL link posted below. Any help with this would be greatly appreciated! Screenshot 2025-09-03 at 4.46.32 PM.pngScreenshot 2025-09-03 at 4.46.56 PM.png
Fabio Racobaldo _Catworkx_
Hi @emills and welcome,
my suggestion is to use an URL field with the URL as default value and make it as read only on user side.
The only cons of this approach is that field value will appear on ticket side if that field is on view screen.
Hope this helps,
Fabio
emills
September 4, 2025
Hey Fabio!
Thank you for the warm welcome, I tried the URL field initially but I ran into the same issue unfortunately. How do you make it read only?
