How can I rename a Jira Workflow?
BarneyB
November 5, 2014
I have created a JIRA workflow. In my haste I spelled one of the words incorrectly.
How can I rename the workflow?
6 votes
Jijo John [DevOps Consultant]
It will not allow you to rename when its active (attached to workflow scheme)
Take a copy of the workflow, rename it, attach to the workflow scheme and remove old workflow from the scheme!
BarneyB
November 5, 2014
Thanks Jijo. Your instructions were spot on.
Christopher Emerson January 18, 2017
Yes thanks. Kind of a silly mechanic the system enforces (renaming should be easy always) but this worked.
Martin Gregory
So how do you really do this when retiring a workflow?   In it's lifetime it's become attached to dozens or more of projects...  now it's name needs to be changed to be clear it isn't active anymore...
Sergio Markovic
June 28, 2016
What's the purpose of that restriction (to simply rename the workflow)?
SimratPal Singh November 5, 2014
You can't. Just copy it with the desired name and associate it with the scheme you want.
Benjamin Horst
November 5, 2014
Register now
