I need only specific users to be able to transition the status of a task from 'code review' to 'Release'. How can I do that? I saw the link below that talks about creating a specific user group and limiting them from making a workflow status change by editing the "properties" in the workflow scheme for that particular status. However, this is not working for me.
Hoping someone can help with the correct implementation design for this need. thanks
Kalpana
Good luck, please ask more questions if you run into any problems.
This is basic workflow editing. Is it possible you should ask an administrator in your system instead?
Regardless, it is documented here: https://confluence.atlassian.com/adminjiracloud/advanced-workflow-configuration-776636620.html#Advancedworkflowconfiguration-conditionsConditions
Simply add a condition to the workflow transition.
Read the story
