How can I see remaining time for my issues in the current sprint?
Olivier Delalleau February 5, 2013
Using Greenhopper 6.1.1, during an active sprint, I can't find a way to see the total remaining time of all issues assigned to me. How is it done?
Olivier
Olivier Delalleau February 6, 2013
Thanks for the other answers. I guess this is indeed a feature request since there is no existing solution, and I believe it would be best solved by this existing feature request:
"As a Rapid Board user, I would like to use Quick Filters on the burndown chart" https://jira.atlassian.com/browse/GHS-4686
Mark DeMichele
One easy feature may be to add it to the work mode when you have swimlanes we to assignee. On our board we have it set that way and it shows the issue counts for each user next the user's names. It would be nice if it summed up other data there, like that remaining time and/or remaining story points.
AhmadDanial
February 6, 2013
Hey there, Mark.
Sounds like an interesting idea. Perhaps you can raise a request in https://jira.atlassian.com/secure/Dashboard.jspa to get the attention from the developers to get this feature to be implemented in GreenHopper in the future.
Warm regards,
Danial
AhmadDanial
February 6, 2013
Hey there, Olivier.
As of now, there is no reporting in GreenHopper that allows you to check on the total remaining time for assigned issues for a single user. The sprint statistics on the Sprint section will show the total amount regardless of the Quick Filter that you apply:
Perhaps this can be considered as a feature request?
Warm regards,
Danial
