How can I send Time to SLA panel data to EazyBi?
이의석 May 9, 2022
Hi, I'm using time to SLA.
I WANT to create visual reports using EazyBi.
Although I followed  the guide below,
https://confluence.snapbytes.com/plugins/servlet/mobile?contentId=38175930#content/view/38175930
It does not provide the way how to send SLA panel data such as weather met or exceeded,
startdate(yymmdd/dd:hh:ss),
targetdate(yymmdd/dd:hh:ss), enddate(yymmdd/dd:hh:ss),
Elapsed time (dd/dd:hh:ss) etc.
Is there any way to use those kinda data in EzyBi?
It is so crucial to my business that I have to know how to apply it.
Best regards.
Lee.
Tuncay Senturk
May 9, 2022
Hi @이의석
Welcome to the Atlassian Community!
Actually, the guide you already mentioned provides the solution for your needs.
You can use following properties in your eazyBI reports;
- slaStatus as SLA Status (whether it is MET or EXCEEDED)
- startDate as SLA Start Date
- endDate as SLA End Date
- targetDate as SLA Target Date
- workingDuration (SLA Elapsed Duration)
Tuncay Senturk
May 9, 2022
If you are having issues/difficulties please raise a support ticket here and the team will help you as soon as possible.
이의석 May 9, 2022
Thank you for your reply, I got the table as belows.
I want to get startdate, endate fiels in YYYY:MM:DD:HH:MM:SS format,
and I can't recognize information in the status field and duration field like that.
pls, assist me to solve this problem.
Thank you in advance.
Regards.
Tuncay Senturk
May 9, 2022
You can use javascript to convert to any format you want. If you need further technical assistance please do not hesitate to raise a support ticket. The team will help.
Absa Thiam July 23, 2022
Bonjour @이의석 @Tuncay Senturk quelqu'un peut m'expliquer comment je dois faire la configuration pour importer les données de Time to SLA sur eazyBI
J'ai utilisé la lien ci dessus pour faire la config mais quand j'ai le bout de code
[jira.customfield_11500]
data_type = "string"
dimension = true
name = "EazyBI Integration Cf"
sur les parametres avancées de eazyBI l'importation de mes données ne passent plus
Aider moi à le faire svp
