How can I set remaining time to 0 automatically when issue resolved or closed
Graeme January 9, 2012
I've seen talk of setting post functions etc., but my understanding is that these can't be created in OnDemand. There also seem to be some JIRA-xxx issues where this is flagged as fixed but I don't see a way to do this.
Thanks.
Jobin Kuruvilla [Adaptavist]
January 9, 2012
Actually, you can modify the workflows to use the out of the box post functions even on onDemand. There is a post function to update the issue field and you can use that function to set the remaining estimate to 0.
January 9, 2012
How do I add post functions. I went to the workflow administration, clicked on the transition name and then on the Post Functions tab, but there is no create option
Graeme January 10, 2012
It worked just great, and now I know how to edit workflows and set post actions. Thank you very much!
Dnyaneshwar Ramesh Borase
Is there any impact on the burndown chart?
If yes then what?
cyberprodigy
May 18, 2020 edited
Please add information on how did you solve this, as I'm still struggling on figuring out which action I need to choose. If I choose "Log work" then I would like to log all the work that's required to set remaining time to 0, but there does not seem to be a way to get time remainig.
If I choose "Edit field" action, then again, I cant seem to find time remaining field on the list I can set.
cyberprodigy
May 18, 2020 edited
I finally figured it out
I needed to write custom json.
At the step "Then:" where i need to specify action, i added "Edit field" and under "Additional Fields" text area pasted this
"fields": {
"timetracking": {
"remainingEstimate": "0"
Nick Capito
June 24, 2020 edited
Just an FYI that will also clear out original estimate.
Try:
"fields": {
"timetracking": {
"remainingEstimate": "0",
"originalEstimate": "{{issue.timetracking.originalEstimate}}"
