I finding this a lot harder than it should be. I can see the projects with a drop down to open another page with the issues, I can see the issues per developer or assigned resource, but I can't seem to find something that just shows how many open issues are for a project?
First, make a saved filter that select your project and only open issues.
Second, add gadget 'Issue Stadistics' in your dashboard and select the saved filter that you make in first step. Save.
This show only all open issues of project (your saved filter)
Hope it helps,
Daniel
on dashboard, select the project from Projects menu then click on issues tab which is on left side, it show all issues information
