How can I sum up times to parent tasks?
Nathael Dreymann
I create several User Stories and add several sub-tasks to each User Story.
For each sub-task I have Original estimate field and Time tracking field.
I created automation to Sum up these times in my User Story (see screenshot attached).
When I change a Time tracking on the sub-task, the Time tracking is updated on the User Story, but I receive a failed email (I don't know why).
However I didn't succeed in created an automation to sum up Original estimate.
Can you please help
Thanks a lot
Nic Brough -Adaptavist-
November 22, 2022
You don't need to do this.  The Stories already display the accumulated time estimates from their sub-tasks (check the time tracking panel, there's an option to include/exclude the accumulated numbers)
When reporting on them, use the Î£ fields (Σoriginal estimate, for example, shows you the accumulated estimates for the current issue and all its sub-tasks)
Nathael Dreymann
Hi Nic,
Thank you for your answer.
I see that the Time tracking is automatic for all the sub-tasks attached to my user story. It works well.
But I don't know how to see, on the user story, the sum of all sub-tasks Original estimate. It remains 0 (see screenshot attached).
Do you know why?
Thanks again for your help
November 28, 2022
The accumulated times are all shown in the "time tracking" section - the original estimate on the issue is zero, but the estimates on the subtasks add up to 4 days. (1 logged and 3 remaining)
Nathael Dreymann
Thanks for your feeback
Emna Elleuch
Hi where we can enable Time Tracking field in the Story?
izabela.majer July 27, 2024
Hi Emma,
On Cloud it is by default enabled:
You have option to log time on "..." and then  in "More fields" it is shown how much time was logged on the tasks.
On Data Center I think you have to add tiem tracking fields to the screen on your own, but I would have to doiuble check that.
Like • Emna Elleuch likes this
Emna Elleuch
July 27, 2024 edited
Thank you Izabella, actually, i was looking for the field Time Tracking or Time Spent at Story Level.
I'm using SUb Tasks (QA and Dev) and wondering if there is a way to calculate the sum and add it at Story level.
@Nathael Dreymann can you please help !
Nathael Dreymann
Hi @Emna Elleuch,
You should check the Screen scheme of your project.
When you click on the name of your screen (eg. R&D Scrum Default issue Screen) you will see the list of all fields you can add or remove for your project.
I hope it helps.
