How can I transition subtasks when parent task has transitioned?
Mina Dimitrijević
November 27, 2024
I have parent tasks that are transitioning and would like to transition all the subtasks of that parent task to the same transition. How do I do that?
3 votes
Ramakrishna _RK_
November 27, 2024
Hi @Mina Dimitrijević ,
You can achieve this through Jira powerful feature 'Jira Automation Rule'. Below is the documentation which gives you complete details.
https://support.atlassian.com/cloud-automation/docs/create-and-configure-jira-automation-rules/
Below is the example screenshot for your reference.
If this answer gives you clarity, please accept it.
Regards
RK
Mina Dimitrijević
November 27, 2024
Thank you for the answer!
