How can I transition to a Step based on resolution?
Aaron
I'm looking to add a new Awaiting QA step within a custom workflow. I have created a new screen and have also added in a new resolution called "Fixed (Needs QA)" Additionally I have created another custom field with a QA Assignee field. Within the validation options of the steps, I didn't see any options that would allow you to check the value of the resolution field (or any field for that matter).
Basically if the resolution is Field (Needs QA) I want to direct the user to my new QA screen, if they select the default fixed resolution the task will just be resolved as usual.
Is there a better way to accomplish the same thing?
Renjith Pillai
February 8, 2013
This is not possible exactly as you mentioned as you are using OnDemand. The closest what you can achieve is to define an additional transition which says "Marked as Fixed (Needs QA)" and show your custom screen in that transition.
Angell April 1, 2013
Renjith is right, I have 7 different possible resolutions for bugs, and each one is it's own transition button.
