How can I use parallel sprints?
Patrick McCarthy February 1, 2019
I have found the various support documetns, but there is no menu item Applications in my version of Jira cloud.
Any idea how I can activate parallel sprints.
Jack Brickey
@Patrick McCarthy, see if this document helps using-parallel-sprints. The document is a bit dated. It should read - Jira settings > Products > Jira software
I read that first, but it is no longer valid.  So there is not Applications menu tab anywhere i can see.
Warren
February 1, 2019
Hi Patrick
Click on Settings as below
then Products
and finally choose Jira - there you will have a checkbox to allow parallel sprints
Jack Brickey
Warren's pic are for Server so if on server use that. if on cloud then follow the instructions i provided
Warren
February 1, 2019
Sorry @Jack Brickey I'm on cloud, the pics match your instructions.
Thats the one.  Problem resolved.  Thanks all!!
