I have a custom field which is a dropdown where I have a list, once I make the selection of an item from that drop, what I need is that in another dropdown, show me just the children of the first selection.
I'm using nFeed for the configuration of the querys that I need for extracting the first list, in theory I already have the query for just extract the children, but what I dont know is how to actually use what is in the fisrt field so it can make the correct extraction of the information that I need for the second field.
PD: I cant use static data because each item on the first field has it own and different children
Are you looking for setup like in the following tutorial -> https://valiantys.atlassian.net/wiki/spaces/NFEED512X/pages/99942650/Configure+dependent+select+lists ?
Are you using a select list cascading custom field type?
No, Im using nFeed, because the info I'm excracting is from a db, and there are a ton of items, so it's not so usefull the select list cascading custom field, because apart of that, there are some children that also have children.
got it. sorry not sure how to help you on that front. Maybe others w/ nfeed experience will chime in here.
good luck!!
Help us plant more trees
