How can I view all currently active sprints
Pieter Stoaling
February 14, 2017
The JIRA instance has multiple sprints which were started but never closed. Is there a way to view them all with a single filter? Rather than going to every board to find out if it has a running sprint, and closing them from there?
Ideally I can view them all as a list, which a way to easily close them all.
Thanks in advance for any help
16 votes
Geoff
  1. Create a filter using the following JQL and save it.  The query will get all issues that are in an open Sprint:
    sprint in openSprints() ORDER BY Rank
  2. Create a new board that uses the filter created in step 1.
  3. Open the board and go to the Backlog view to see a list of all the open Sprints and the issues in the Sprints.  You need to use the Backlog view since the Active Sprints view appears to merge all the issues into one Sprint.
Hope this is what you are looking for.
chris.reyes
February 5, 2020
Thanks.  That completely helped!
Like Hasitha Udayanga likes this
Joel Lehnert
March 10, 2022
Thank you, helped me too, perfectly.
For me it was mostly open sprints on old projects. So I excluded running projects:
sprint in openSprints() AND project not in (project1, project2) ORDER BY Rank
Like 2 people like this
Matej Ferenčík
April 22, 2024 edited
Thanks this is GOLD!!
I am working on 11projects and to give the "ALL" view I used: Sprint in openSprints() AND Sprint not in futureSprints() AND project in (Project1,Project2,Project3,Project4,......,Project11)
worked like a charm
Like Geoff likes this
Hristo Petev
February 13, 2025
I tried it just as filter in the issues list and it worked like a charm!
Matt Wynne September 28, 2023
Additionally, a (revised?) feature of JIRA cloud I just found; a newly created Sprint is only visible to the creator in the Backlog as long as it's empty / with no items in it. As soon as someone adds an item to the Sprint, then it becomes visible in the Backlog and usable by the project users with permissions.
Help us plant more trees
