How can i Copy subtask comments to Parent task via automation rule
Ishwar_chand March 27, 2025
3 votes
Sergei Troshin
March 27, 2025 edited
Hi @Ishwar_chand and Welcome to Atlassian Community!
You can easily achieve this using the following sequence of blocks:
1) Add the Issue Commented trigger:screen1.png
2) Check if the comment was added to a sub-task:
3) If the condition is met, add a branch and switch to the parent issue:
4) Post a comment. 🙂
Hope this helps! 🚀 If you encounter any difficulties, feel free to ask me, and I'll do my best to help.
The rule is functioning correctly; however, it only copies comments made by the reporter. Comments from other users on sub-tickets are not copied to the parent ticket.
Sergei Troshin
March 27, 2025
Hi @Ishwar_chand again!
I've just tested and comment successfully copied from me and another test user:
Could you please explain better your problem?
Ashish is report here his comments are sync to parent but another use comments are not.
Manoj Gangwar
Hi @Ishwar_chand Welcome to the Community!
You can create an automation rule like below.
Trigger- Issue Commented
Condition- Issue Type = Sub-task
Branch For Parent
Action Comment on Issue
Paste this under the comment
{{comment.author.displayName}}
{{comment.body}}
Is it correct?
Sergei Troshin
March 27, 2025
@Ishwar_chand that's partially correct.
Please review the second screenshot in my answer.
Like Manoj Gangwar likes this
Learn more
