How can i disable sending Notifications by Automation?
Nico
HI, my customers are bombed with email notifications!
How can i disable the notification, when Status was changes from or to "Waiting for Customer" or "Waiting for Support"
Its enough if the user get the comment itself, antoher mail is unnecassary
Daniel Ebers
February 15, 2021
Hi @Nico
sure - you can adjust the customer notifications to your needs.
Following two documents should get you started:
Daniel
Nico
Hi Daniel, thank you. But i dont get it. Where can i disable that the automation sends email.
there are mails with "Automation changed status to waiting for suppoer"
I dont find the place where i can disable it. In your link i see project settings > customer notifcation > customer visible status
But what is a customer visible status?
Daniel Ebers
February 15, 2021
If you are sure Automation changes it directly you can find it in your project under Automation.
The question here is, is it a mail from Automation directly, a customer notification or an agent notification? The format of the mail should tell it, they look pretty different.
Nico
The mail looks like this. This is unnacessary. Also if a supporter add a comment, then the user will get "status changed waiting for customer"image.png
Daniel Ebers
February 15, 2021
I'd say you can disable it by clicking on the green switch:
This direct link should you get there:
https://YourGreatSiteName.atlassian.net/servicedesk/admin/YOURPROJECTNAME/customer-notifications
Nico
February 15, 2021 edited
I think thats it! That was a way to easy! Thank you very much
Nico
Is there a way to prevent it also, that agents dont receive mails by automation app?
Daniel Ebers
February 16, 2021
I think there is a check box in the automation rule to exclude sending mail - but you might be better asking in a separate thread for automation specialists.
It also depend a bit on the rule.
FREE
