×How can i take Jira cloud backup & restore for single project or multiple projects and automatic backup, please suggest me any plugins in Jira cloud
easy way to export your data but if you have many issues when export to waste to much time and size file verry large so i recommen you use option two (file just only data)
Optione two (file zip backup have config system,data,info jira,project..)
Jira Admin ->Jira settings->System->Backup Manager. In there you have two options: Create backup for cloud and Create backup for server
I hope you find this helpful!
Thanks ,
Venkatesh Penumuchu.
i have to do automatic backup for daily like scheduled Automatic Jira cloud backup everyday.
Yes, i want both all Jira backup and one project backup also
If You Want All project You will Go To Jira settings >>Backup Manager >>Back up for cloud.
If You Want Single Project Jia>>Issues an Filters >> search issues >>Filter >> Export
Ex:Filter is PROJECT=TEST
when you do that filter all issues Take a Export A .XML And import that project data
Find the Attachment
quick question, you suggest taking a XML backup, which I can understand preservice the data structure better as it is able to represent nested objects in a way that is difficult for CSV. However, I can not see a way to import XML.
Is there a way to import XML in jira cloud?
Please note that (as of October 2024) only a maximum of 1000 issues can be exported at once.
Option one. It's the easy way to export your data but if you have many issues when export to waste to much time and size file verry large so i recommen you use option two (file just only data)
Venkatesh Penumuchu
