How can we implement WIP limits at a Swimlane level in a column?
Edward Sigamani
September 9, 2019
In a Kanban board, while we could implement WIP limits at Column level, how can we implement WIP limits at a Swimlane level in a column?
Susan Puckett June 28, 2023
I wish I had a solution.  I need this feature!
CESAR DALDOSSO March 19, 2024
me too
Greg
A plugin or app that might address this issue: Advanced Agile & Kanban Boards by Release Management.
Jovan Jakovljević
December 23, 2021
On JIRA Cloud this is now possible. WIP per swimlane.
Weston McNamee
February 10, 2022
How is this done?
Like # people like this
Thomas B
September 9, 2019
@Edward Sigamani go to your Board > Configure > Columns and you can set a MIN / MAX for each column.
You need to set your Column Constraint = 'Issue Count' before you can set the MIN / MAX
Edward Sigamani
September 12, 2019
Thanks - yes do have the  Column Constraint = 'Issue Count' before you can set the MIN / MAX but still cannot have WIP limit set at swimlane level within a column.
Thomas B
September 12, 2019
@Edward Sigamani do you see the following that I've highlighted? The column MIN / MAX would limit the number of cards you can have in any column at any time. Are you talking about hours and not cards?
Like Mars Penton likes this
Herb van den Dool
November 14, 2019
Test
The OP is asking about setting WIP limits at a swimlane (horizontal grouping) level. I wish this was possible as well as the option to set WIP limits per person or component. Sad that Jira has been "gathering interest" on these capabilities for nearly a decade and yet has such scant support for Kanban practices.
George
this is still not possible?
G Walley
October 26, 2021
It would be very helpful to group columns and add a maximum limit to the group as a whole.
