We are planning to get the values from resource groups to multiselect custom field in Jira, Do we have any solution, please suggest me?
Hi @Julie d_Antin _Elements_ We are planning to write groovy script in script runner, Can we get sample code for getting azure resource groups? thanks
Hi @Yendapally ,
I'm with the team behind Elements Connect, not Scriptrunner (made by Adaptavist) so I won't be able to help you with a groovy script.
If you need help configuring your datasource with Elements Connect, don't hesitate to contact our support team:
Hi @Yendapally
Welcome to the community,
If you need to retrieve value from external API to populate customfield option, you can try a plugin like Nfeed.
https://marketplace.atlassian.com/apps/23337/elements-connect-external-data-fields
Thanks for the mention @Mohamed Benziane Nfeed is now called Elements Connect.
@Yendapally If you want to get an idea of how Elements Connect works and see examples of getting data from REST APIs, check out the getting started guide or our demo portal.
