How can we resize the "step to reproduce" section within the issue detailed view?
duy tran quang February 9, 2018 edited
would like to enlarge the step to reproduce section like the description one for instance.
how to resize the this section within the issue detailed view?
duy tran quang February 12, 2018
thanks for your reply.
Have you guys noticed that the width has changed ? It's less readable and it would be great to be able to resize it.
btw, description is not a custom field but a standard one.
Nic Brough -Adaptavist-
February 12, 2018
You asked about "steps to reproduce", not description.
Cloud changes a lot, I can't say I'd noticed.
February 10, 2018
You can't change the size of the standard custom fields in Jira.
If the field is being provided by an add-on, then it might be resizable if the add-on vendor has coded for it.
