Resize Details pane
Kjetil Johannesen
September 15, 2023
Hi, any way to increase width of Details pane or alternatively place Fix versions field somewhere else so it's possible to view the whole value?
With our long names it's not possible to see the version number (see image).
Marc - Devoteam
September 15, 2023
Hi @Kjetil Johannesen
Welcome to the community
You are able to adjust the width of the details pane, this will take into account the fields in the details pane as well.
Hoover between the main section and the detail a blue size bar will appear, this gives the opportunity to adjust the size of the details pane
as is:
after:
P.S tis is a personal user setting, this can't be enforced system wide.
Kjetil Johannesen
September 15, 2023
Great, thanks for showing :)
