×I wanted to apply the security settings we've standardized to next-gen projects but I don't see it in the project settings menu.
Permission and security schemes do not apply to Next-gen projects. I have a feeling they never will.
You can remove the capability to create next-gen project.
Go to Jira settings -> System -> Global Permissions. And make modification to the Create Next-gen Projects permission.
Venkatesh.
Hi, @PVS thank you for taking the time to answer my question. However, that is not the answer I am seeking.
I'm looking for the ability to apply for Permission and Security settings you create in Project Settings > Permissions or Issue Security so you can use it to next-gen project just as you would the standard projects.
