×Hello,
I am trying to get my hands dirty with Jira and Testrail as a new QA Test Engineer and was wondering if there are dummy projects I can upload on the free account and get a better understanding of how things are done.
Your help is highly appreciated.
There previously was the ability to add sample data when creating a new project but I am not immediately seeing it now in the newer project creation process. It may have been relocated or done away with. With that said it did not accommodate Testrail data. I recommend using CSV Importer to create your sample data. You could export data from an actual project, massage the CSV file and then import into sample project.
