How do I add a field to Sprint Report
Meenakshi Khanna May 29, 2018
I want to add field assignee to Sprint report.
Please tell me steps to do so ( Thanks )
Martins Vanags_eazyBI
I believe this should be possible using eazyBI
Perhaps you could see some more report examples on eazyBI demo account:
https://eazybi.com/accounts/1000/dashboards/5956-sprints-overview
Martins / eazyBI team
Jack Brickey
what is your goal? I simply click on View in issue navigator and add my columns there. You can also save the filter and add to the dashboard displaying whatever fields you want.
Bimlesh Sharma September 8, 2021
This answer does not deserve to this question.
Jack Brickey
@Bimlesh Sharma , Thanks for your input. Do you mean to say that the answer is not relevant to the question? Is there some action that should be done to make things ‘right’? Please advise.
Chris Wagner
December 20, 2022 edited
Same challenge on the above answer as Bimlesh.  We know we can drill into each and every issue to get more detail, but we want the summary view this Report provides.
For example, I want to extend my Sprint Report with additional columns so I can see at a glance
a) which Assignee has the most not completed work,
b) sort by Ranking field so I can see if higher priority stories are being tackled early,
c) look at Dev Due dates in a block to see if incomplete work is past due,
d) remove Story Points in favor of columns we care about
etc.
Much of this can be done with Issue Filters, except (afaik) for an out of box the way to see which issues have been moved out of the Sprint (*due to my Firm's locked down templates and resistance to adding plugins, we can't lock the Issue Sprint field, so the Sprint Report is the only way we've found, without Reading each issue History trail, to see at glance when issues hop Sprints).  Note: we are not using JIRA Cloud.
I suppose if there was a JQL way to recreate this report's "Issues Removed from Sprint", I could build my own Report :-)  So another vote for https://jira.atlassian.com/browse/JSWSERVER-20097
Tarun Sapra
Tarun Sapra
Though with plugins like Better Excel and eazyBI this should be doable but both of these are paid plugins.
Like Martins Vanags_eazyBI likes this
