How do I add custom fields from an issue type that has custom fields to a Form?
When I try to create a Form, there are default fields availalbe. Since this is a team-managed project, I'm guessing this is a limitation to the company-managed projects where I can modify Issue Type Schemes with custom fields that can be added to a Form.
I'm hoping the community may have run into this and has a suggestion.
Thank you in advance.
Hello @Will ,
Team Managed projects having limitations.
I think the below link might be helpful to you.
https://support.atlassian.com/jira-software-cloud/docs/customize-an-issues-fields-in-team-managed-projects/
Check this.
Anvesh
This page doesn't really address whether the fields can be added to forms or not!
