×Hi, my question is how to check if on our JIRA installation on cmservices.atlassian.com RPC plugin is installed?
I need RPC plugin to be able to post bugs from testing software suit, to Jira.
Please provide instructions as on how to check and install RPC plugin.
Mathijs
You can't install add-ons like that in Cloud.
Even if you could, you wouldn't have it - RPC was deprecated a while ago and it does not work for more recent versions of JIRA.
Whatever you're trying to do, it needs to use either the UI, REST or Connect addons (which use REST anyway)
I am using TestComplete for test automation. I want to upload found bugs to Jira.
According to this article JIRA is supported up to version 6.4.7 .
At the moment I am getting an error code 415 when trying to connect to our JIRA system from TestComplete.
Cloud is well past JIRA 6.4.7, so it's not going to work. You'll need TestComplete to provide a version of it that works over REST (and/or a Connect addon)
Thanks for the confusion. I noticed TestComplete 11.20 - JIRA 7.1 integration is actually working.
Point was I had to use "https://" preface instead of http:// , and I had to use login name (NOT email address) in TestComplete to succesfully connect to JIRA, and post issue.
You hadn't mentioned that you were using the wrong settings. There's no way we could have known that.
Correct. Also, I couldn't have known that it would be operative. Since in the documentation is stated that JIRA is supported up to version 6.4.7
