How do I close a reopened issue?
Deleted user June 21, 2013
I am the administrator but do not see anything resembling a "Close" or "Resolve" button when viewing issues with a "Reopened" status.
Randall Robertson
June 21, 2013
The Permission Helper tool can tell you what conditions must be met for you to see the close transition if this is a permission problem and not a simple workflow disconnect.
Deleted user July 7, 2013
Randall, thanks, that's a great little tool. I have a feeling I'm going to be using it a lot.
Randall Robertson
July 7, 2013
It comes in handy, especially if you are helping others project leads learn how to manage their project permissions.
Nic Brough -Adaptavist-
June 21, 2013
It depends on your work flow. You do not match the conditions set for those transitions (if they exist at all!), so you cannot use them. Admin rights do not matter here, they give you add-on rights, not "can do everything" (because that's a really bad usage model), but, as an admin, you can read (and edit) the workflow and change your settings so that you do match
Thanks, Nic. As a brand new user, I have a lot to learn, but I really like JIRA so far.
June 21, 2013
Register now
