×We are using Google Apps accounts to sign into Bitbucket. When team members first signed in, they created new Bitbucket users and set their Bitbucket usernames freely.
E.g., I logged in using my Google Apps account itamar@company.com, but since "itamar" is already taken as a Bitbucket username, I chose the username "itamar_company".
Now we want to use JIRA OnDemand, using the same Google Apps accounts. But JIRA OnDemand sets the usernames straight from our emails (e.g. my username is "itamar" and I can't change it).
When importing issues from Bitbucket issue tracker to JIRA OnDemand, the Bitbucket users are imported along, and we are left with two inconsistent sets of users (e.g. "itamar" is the user I can actually use with JIRA OnDemand, but "itamar_company" is the user that has issues assigned, and the user who is active on Bitbucket).
Is there a way to "merge" users on JIRA OnDemand? Or force it to use our Bitbucket usernames?
I think your best bet in this situation would be to bulk assign issues from the imported user name to the existing user name on JIRA side, and upon completion disable the imported username in order to prevent it from counting toward your license limit.
Thanks. That's a valid option.
Just a few concerns I'd like to resolve before actually doing this:
JIRA DVCS Connector will set up links between your repositories and your JIRA account, you can check those manually from the repository. Go to your repo settings on Bitbucket, and click on "links" and you should see the links that Bitbucket has to your JIRA URL.
As for actions performed from JIRA, Bitbucket will check if you have a session in the browser logged into your Bitbucket account, and will make API calls for the request to perform these operations. So authentication is done in the background, if there's no sessions, then Bitbucket will ask you to login.
I found how to bulk change assignee and reporter on issues,
but is there a way to bulk edit the user of issue comments?
Also, the Bitbucket issues are imported with their Bitbucket watchlists. Is there a way to bulk edit the watchlists user to the JIRA users?
btw, how do I "disable" the imported user? I could not find such an operation in the user management view.
