Using project automatisation I would like to copy the value of a custom single-choice field (cf_11003) to another custom field. This custom field is of the type multi-choice (cf_11600) and has the same values as cf_11003.
I tried using:
"fields": {
"Kunden-Projekt": {
"value": "{{issue.parent.fields.customfield_11600.value.asJsonStringArray}}"
}With this code I get the following error:
(data was not an array (Kunden-Projekt))
Any advice on how to solve this issue?
Dear @Thorsten Witt ,
I have no clue about Automation, but probably this helps:
Selecting a single option for a multi select field would look like this in pure JSON:
"fields": {
"customfield_11600": [
"value": "Project X"
I guess that
will return
"value": Project Y"
But when you substitute this in your upper example, it can't work.
Can you output
in a log file for debugging? And from the logic, don't you need to use this instead?
{{issue.parent.fields.customfield_11003.value.asJsonStringArray}}
So long
Thomas
