How do I create an automation to update a label when the QA Subtask is assigned to a certain QA person?
Glen
Have you started and automation rule and it is not working as expected? If so, context is important for the community to help. Please post the following:
If you have not started started a rule yet, perhaps review this documentation to create the rule:
Hi @Glen Brannigan You can try setting up the rule like below.
See below error I'm getting
Issue assigned
03/10/2025, 14:56:31
Issue fields condition
We excluded the configured field from this action as it couldn't be found:
Subtask
Just one more question, on the above how do i set up automaton so it adds the label to the parent ticket and not the subtask
Glen
@Glen Brannigan Kindly mark my answer as accepted if that helps. For your second question, you can try like below.
1. Create a rule with when the value changes for assignee field
2. compare it to the QA peers list
3. Add a label.
I have included a screen shot of the rule. Hope this helps.
Save your spot
