How do I create an editable and filterable list of issues?
Marcus Vasilios
September 23, 2024
Hi all,
Somewhat a beginner with Jira, apologies if this is a very basic question...
I have a list of issues which need grooming periodically with a group of stakeholders.
I would normally just export the issues into an excel file with the fields I want and then filter on each stakeholder group, make relevant changes to the issues in the sheet, then manually make the same updates later after the grooming session (if I did this during the session they would take much longer).
Is there a way to see all my issues in a similar layout to a worksheet, so that stakeholders can easily see all the relevant fields and records, but also have the ability to update the fields to directly in the issues to avoid double work?
thanks!
4 votes
Nikola Perisic
Welcome to the community @Marcus Vasilios
Have you tried using the List feature in Jira? It gives you the overview of issues in table like looking format where you can do the updates right from the get go.
Marcus Vasilios
September 23, 2024
Thanks Nikola, this is exactly what I was looking for!
Like Nikola Perisic likes this
Help us plant more trees
