  • Community
  • Q&A
  • Jira
  • Questions
  • How do I create automation to both "flag" and change issue color when a field condition isn't met?
Kyle Wilz June 27, 2025
I am trying to create an automation that will:
- Flag the Issue
- Change the Issue Color
When our custom field "category" is empty when the issue is transitioned to "In Progress"
Gor Greyan
June 28, 2025
Hi @Kyle Wilz
Thanks for the questions.
Your automation looks fine, except for the following points.
For the flag edit action, you can use the following JSON in the advanced field.
"fields": {
"flagged": {
"value": "Impediment"
For the card color, Jira doesn't allow direct card color change via automation, but board colors are configured via JQL in the boards settings.
Usually used:
-Labels
-Priorities
-Flags
You can do the following workaround and change the card color via the label.
Add another action: Edit issues
Change labels (for example: labels = missing-category)
Then go to Board settings:
Choose queries
Add rule: labels = missing-category --> Choose a color
Let me know if you have any questions.
Thorsten Letschert _Decadis AG_
Hey @Kyle Wilz ,
Flagging is already working via your automation rule?
For card colors, go to the board settings (see https://support.atlassian.com/jira-software-cloud/docs/customize-cards/) and configure the color—in your case, probably by queries/JQL.
Thorsten
