I have a Cypress test suite that creates an xml report upon completion. I then import those test results using the /api/v2/import/execution/junit endpoint. This is functioning, but the resulting test execution will have a summary like "Execution results [1725561773655]". What does this code correspond to? And is there a way I can define the summary automatically?
This is all happening in a Gitlab CI. Best case scenario is that I could include a Gitlab predefined variable in the Test Execution summary so that I could trace the Test Execution back to the merge request it was testing.
Hi @Pratt, Trenton - welcome to the community,
unfortunately it‘s not possible directly within the same call.
I managed to do a similar thing in a github action by creating a test exdcution issue via the native jira rest api and saving the key in a variable right before importing the cypress test results. I could then use the variable within the import call.
Let me know if this is helpful or if you have any further questions.
Best
Stefan
Thanks for the help!
