How do I disable Ranking = "Using Ranking", so I can use custom sort?
Brian G
Hi.
I am trying to create a custom sort for backlog view (JQL query)
project = XXX AND issuetype = Task AND status != Removed AND status != Done ORDER BY status ASC, priority DESC
However, it when selecting Backlog > Board settings > General > Saved Filter and updating to above query, it is never saved because what I assume is because "Filter Query = project = XXX ORDER BY Rank ASC" and "Ranking = Using Ranking". Filter Query and Ranking in not editable!!!
Choon Keat Seet
You need to change the filter,
* you can click on the "Edit filter query" link above which will bring you to the filter
* and you can edit and save.
If you cant save the filter ,you don't have permissions to edit, in which case , you click on details to see who is the owner
Brian G
How do I change the owner?
Brian G
I think I found it here https://community.atlassian.com/t5/Agile-questions/Changing-a-Board-owner-as-a-system-admin/qaq-p/437899
just use this URL: <JIRA-URL>/secure/admin/filters/ViewSharedFilters.jspa
