How do I embed a survey link into my Portal announcement?
Victoria Bak
I recently ask if I can send surveys NOT attached to a resolved ticket, but wanted to focus more on active customers.  I was told here in the user group "You can either send notification to the customer through automation or have a link to your survey in the banner part of portal"
I can create the customized survey.
I can add a note to the banner part of the Portal.
But I'm having issues having trouble creating a shareable link to the survey.  I can get a link by setting up automation for when a ticket is resolved, but I can't just embed that link in a portal message.  If you've done this, or know how to do this - please provide some additional details in getting and sharing the link to the survey.
Thanks in advance!
Laura Humphries
February 7, 2025
Hey @Victoria Bak
You'll need to use wiki markup to get the url to display as a hyperlink. Here's a link to the wiki markup for links specifically:
https://jira.atlassian.com/secure/WikiRendererHelpAction.jspa?section=links
That is how to share a link via the portal. As for how to get the link in the first place, I am wondering how you managed it via automation?
Victoria Bak
So far, I haven't.  I've been using a link triggered by moving a ticket to in-progress, but this may be a stopper.  Support says, it's not currently doable, which doesn't make sense to me...
Laura Humphries
February 13, 2025
Well if you're referring to the CSAT offered 'out of the box', I'm afraid I'm not aware of a way to send this separately or outside of a request being resolved.
The only alternative I can think of would be to use a third party solution to generate a survey and shareable link.
Learn more
