I can't find it under administration and it seems to be enabled under plugins.
To expand a bit, if you signed up for Greenhopper while setting up your OnDemand account, you should have the agile tab. If you didn't initially sign up for Greenhopper, you can make that change at my.atlassian.com If your account is setup for Greenhopper and you don't have the agile tab, best to open a support request and we can resolve the issue right away.
I have a trial license but can't figure out where to put it.... doc says to use admin gadget but graphic looks totally different on my admin interface.
Can you attach your screenshot? What version of Jira are you using?
You'll need to purchase or acquire a Greenhopper license
