Jira App messages from Slack are draining my battery, I want no bot messages to send me a notification or watch notification. How do I configure it to only do that on my desktop? It's draining my battery.
I added the app to a Slack channel and control the communication preferences that way. However, the Jira app itself still continues to send me direct messages where I cannot configure notification preferences.
Just found the answer:
Hi Ruth
Are you using a work email on your phone? Or did you add a mobile plugin to your JIRA?
Best,
Apologies, I thought I added it. It's a plugin between Slack and Jira. I've updated my question for clarity.
Save your spot
