×I have a project with 600 items. 300 in the active fixVersion, 200 in the NEXT version and 100 that are empty.
When I go to the summary view I get a subset of issues in the status overview. I have 2 basic questions
What is the filter that is being used on the Summary view tab in the horizontal menu bar?
Can I set a filter on a fixVersion I have setup (i.e. v6.0 vs v6.1)
Hi @Mark McFadden ,
You can apply a filter. However, the filter is based on a pre-fix list.
Here's the list of filters that you can select from in the summary view:
https://support.atlassian.com/jira-software-cloud/docs/what-is-the-summary-view/
do not see Fix version as being an option.
