How do I get issue key after I create jira issue using create_issue() in jira module in python?
anmol sharma
May 7, 2019
When I create a jira ticket using create_issue function in jira module in python, I'm not able to extract that  issue's key even after the ticket was successfully created. How do I get the issue key?
2 accepted
Tarun Sapra
Hello @anmol sharma
As per the docs
https://jira.readthedocs.io/en/master/examples.html#issues
"Successfully created issues will contain the issue object as a value of the issue key."
Tarun Sapra
issues = jira.create_issues(field_list=issue_list)
Joe Webb
June 19, 2023
It gives you that issue because the create_issue command returns the issue key not a JSON object so in the following example you can use the output as the new key
I.E
new_issue_key = auth_jira.create_issue(fields=issue_dict)
print(new_issue_key)
$ JRA-98
Elifcan Cakmak
May 7, 2019
After creating the ticket, result should return a JSON such as:
"id": "12345",
"key": "KT-5",
"self": "https://jiraurl/rest/api/2/issue/12345"
Here you can extract the key by using :
result_json["key"]
 Regards.
Edgar Oregel
This did not work for me. I tried to index and got the error:
Arguments: (TypeError("'Issue' object is not subscriptable",),)
When i try to loop through the items of the object to see if it indeed returned a Json item, i get error:
Arguments: (TypeError("'Issue' object is not iterable",),)
If i print out typeof(new_issue), i get:
<class 'jira.resources.Issue'>
