How do I insert a table from Excel table into JIRA without having to format it for HTML?
Andrew Milden
September 26, 2018
I want to be able to copy this kind of table into the description field of my JIRA issues.
Joe Charman
If you have WYSIWYG on then you will be able to add a table in the default description field.
You'll find a '+' icon which will provide a dropdown with table as an option.
Andrey
September 28, 2018 edited
Andrew Milden
September 28, 2018
@Joe Charman
Can you provide screenshots or steps to help us navigate towards the right solution?
