How do I know the sprint ID number of a CURRENT sprint?
Theodore Duffy
Is there anywhere that this is actually visible? I need the ID to fit into Filter search criteria.
I just need a report other than the Active Sprint columns, where I get an easily read list of all the tasks in a specific Sprint.
5 votes
Aashish Trivedi
The hack that I use is:
  1. Go to All issues
  2. Click on "Advanced search" next to the text box on the top
  3. Then in the basic view of filters, select the current sprint as a criteria
  4. Then switch to advanced view of the filter and it shows the sprint ID in the query
The query with the sprint id will look something like:
project = XX AND sprint = ID ...
Amos Devakumar
July 7, 2020
Nice hack and it works perfectly.
Like • 2 people like this
Gabor Nagy _Midori_
October 22, 2015
There might exist multiple active sprints. Try
sprint in openSprints()
See https://confluence.atlassian.com/jira/advanced-searching-functions-338363497.html#AdvancedSearchingFunctions-openSprints()
You can also write
sprint in (56)
or
sprint in (55,56)
where 55 and 56 are Sprint IDs. To get to know the ID of a sprint, you have two options:
  • Since Sprint ID is just a hidden custom field, you can export an issue that you know it belongs to the Sprint you need and export it as XML, then look for <customfield id="customfield_xxxxx" key="com.pyxis.greenhopper.jira:gh-sprint"> in the XML. The Sprint ID will be stored here.
  • When you are in JIRA Agile Backlog view, open up your browser's console (press F12 in Chrome or Firefox) and run this code in the Console tab:
    $=AJS.$;$.map($(".ghx-sprint-group &gt; div"), function(sprint) { return $(sprint).find(".ghx-name").text() + " -&gt; ID=" + $(sprint).data("sprint-id"); })
    If you only need the active sprints, run this:
    $=AJS.$;$.map($(".ghx-sprint-group &gt; div.ghx-sprint-active"), function(sprint) { return $(sprint).find(".ghx-name").text() + " -&gt; ID=" + $(sprint).data("sprint-id"); })
Theodore Duffy
No such icon in the Backlog view, sorry.
Jobin Kuruvilla [Adaptavist]
October 22, 2015
Which version are you using?
Soumya Veerachandran
March 11, 2019
no such icon in  backlog view
Theodore Duffy
Gabor,
I need the sprint ID number.
Gabor Nagy _Midori_
October 23, 2015
Please look at my edited answer above. If you need more info, please add it as a comment to that post.
Like • QMetry Sales likes this
October 22, 2015
In the "Backlog" view, you will find an option to "View in Issue Navigator" along side the sprint name. It is a small icon with 3 small dashes and a rectangle.
When you click on it, it takes you to the issue navigator and the query will have the correct sprint id in it.
