×I am trying to set up a wallboard for my team using a Raspberry Pi. I have the device up and running in kiosk mode, my problem now is how to get it to display the wallboard as it is no longer possible to embed creds into a URL. How can I work around this?
Alternatively, is there a way to display a wallboard using an Apple TV?
Many thanks,
Sheri
This is a re-post. Original was posted on a Sunday, which was probably a bad idea.
Hi Sheri
We face the same problem. Wallboards on our on-premise installation work fine. Wallboards on our cloud instance are not accessible. Hate to loose this feature if we switch to the cloud of Atlassian.
Did you have any updates on this ?
Kind regards
Koen
Hi Koen,
I ultimately wound up using a Remix device - specifically the Jide Remix Mini. It is really inexpensive and provides a UI that you can use to log in to Jira and access the dashbord. I've been running it for several weeks now with no problems.
Best regards,
Sheri
