×Our engineering department needs to make the fix version field required but only wants to make it mandatory upon transition from one status to another status. I can't find a solution. I've tried adding a condition in the workflow transition, that didn't work. Is there any way to do this natively without using a third party add-on? This seems like an easy thing to do, however I can't find a way do this.
Hi @SC
Welcome to Atlassian Community!!
You can use a validators in your workflow, please refer below article which helps you.
https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-issue-workflows/
Raju
Thank you @raju mandapaka and @Rilwan Ahmed This is very helpful. I'll test several of the options, and repost if I run into more trouble after I test these possible solutions.
As per Atlassian, this is not possible without a third party add-on.
https://confluence.atlassian.com/jirakb/make-custom-fields-required-in-a-workflow-transition-in-jira-server-691011903.html
You can make use of Teamlead Toolkit or Jira suite utilities add-on for this purpose.
