You don't, it's not really that useful an idea as there's no real way a merge process can know what you want from the process.
I would take the two filters at the heart of the boards and "merge" them - come up with a single filter that returns both sets of issues. Then create a new Kanban board that uses that, and then take the settings from the original boards and work out which ones you want to keep.
@Tami Cook - are you wanting to merge Kanban boards that reside in the same JIRA instance or Kanban boards that are in two different JIRA instances? -wc
